P1151 Question
98 Contour
Bangor, PA
Hello all, this is a great forum, lots of good info!
I have a 98 Contour, 2.5 MTX, 71,000 miles, with a recent tuneup (plugs & wires). CEL is on, throwing a P1151 code. After searching the forum, I've narrowed this to three most-likely possibilities:
-bad bank 2 O2 sensor
-vacuum leak
-possible problem with the IAC valve.
In addition, the car "mooses" in cold weather, and tries to stall when it's been run for a while (usually over 1/2 an hour).
Before I start replacing things, I figured I would ask here to see if this is a common problem or if there is anything else I should be checking. Any help is appreciated. Thanks!
Chris
Okay, so it looks like I'll have to replace both.
Will replacing the IAC help with the poor warm idle, or is that more related to the bad O2?
Thanks for the fast reply!
Chris
It's probably related to the O2 sensor. The idle kinda drops down when you're sitting at a stop or something, right?
Chris
Bad Idle Air Control (IAC) Valve = idle issues.
Bad O2 sensor = Bad O2 sensor
