enigma11211
just had my MSDS header installed with MIL's, and everything was running fine at first. but now my check engine light is on after i drove it about 200 miles.
Yep. Take it to Autozone or Advance Auto, get the codes read (free service) and post the exact codes here.So whats the code?
It may or may not be header related.
i took it back to the mechanic and he said something do with the 02 sensor bank 1 and bank 2.Yep. Take it to Autozone or Advance Auto, get the codes read (free service) and post the exact codes here.
the mechanic put the one that came with the header from msds. i did buy him a set from pony express but never used them.it's probably coming from your MILs then. Double check that they are properly installed.
Where did you get them from? And what wires were cut and the MILs installed on? Only the black and grey wires should have been used for the mils.
ok i'll him know. thanks!I would make sure that the MILs are wired correctly.
So whats the code?
[FONT=arial,verdana,helvetica,sans-serif]P0136[/FONT][FONT=arial,verdana,helvetica,sans-serif]Downstream Heated Oxygen Sensor circuit fault - Bank No. 1. [/FONT]
[FONT=arial,verdana,helvetica,sans-serif]P0156[/FONT][FONT=arial,verdana,helvetica,sans-serif]Downstream Heated Oxygen Sensor circuit fault - Bank No. 2. [/FONT]
bad mils or a bad install of them ...
If you install the ones from Pony Express (correctly), you should not have those two (P0136 and P0156) codes. I have used mine for the past two years... i did buy him a set from pony express but never used them.
