this is berrymans- $3.49 at AutoZone....
pour right into gas tank-
also works wonders in the crankcase, (only use 1/4 of the can in oil)but you MUST drain it out imediatly--while HOT!!!-let run 5-10mins then drain- like a pressure washer for the inside of the block:laugh: but if you don't drain it hot while still hot it will PERMANENTLY stick all the crap to your internal parts!!
i usually put 1/4 in oil and pour the rest in the tank- just make sure you're ready to change the oil!!
BTW-i also love HEET, just never used it for anything but moisture!
