Laura, I agree.
One thing you mentioned was the computer using the knock sensor. From what I believe I understand the Ford EEC-IV also 'learns' from the driver and condition, so if you run with higher octane and can utilize the higher timing curves w/o detonation, the car will have a more aggresive tune as a baseline. At least that's how I interpretted it :shrug: ...
-J
EEC-IV is a great automotive computer system. One of the best ever devised. So good, in fact, that it was in use from about 1984 all the way through 1995 with little change.
As with most all automotive computer systems, including OBD-II, they don't make changes instantly, so you're right about the car having to learn about what is happening -- what kind of fuel is being used, what the driver's intentions are, etc. All of this is in addition to the standard stoichiometric tables and knock sensor timing programming, etc.
Stylin55 oh said:...94...if nothing else it makes me feel like the car is happier
The ol' butt dyno is probably just in your head. Once you hit 91, that's pretty much all she wrote. However, I'll be the first to say that a clean car is good for 10 horse, and that's probably the same effect that's in play with regard to your fuel comment.
