SVT3391
Short version:
1. Car died with drained battery while driving. Jump started the car, but won't last
2. Recharged the battery and drove car back home. No ALT voltage
3. Recharged battery on the car. Showed both correct ALT and BAT voltage
4. Drove the car 10 mins, then no ALT voltage again
5. What should I do next????
Full version
Hi guys,
Last Thursday I experienced sputtering and losing power where I was driving after an hour of stop and go traffic jam. It was driving like normal until I turn on the headlight (HID from Keyser's GB). I pulled the car over to an APT parking lot. The dash light was gone and the techometer was dead at 0 RPM. I stopped the engine, and could not turn it over. Some people gave me a jump start and it started immediately, but as soon as the jump cable was removed, the car would not idel smoothly, then eventually died. I had it jump started 3 times. All behaved the same. Eventually there was simply no charge left in the battery and no interior light. So I simply leave my car there.
Saturday I went with my tools. I took out the battery and went to NTB where I bought the battery 1 year ago. They checked the voltage, 11.5V, and claimed it was good.
I went home, used the smart charger I have to recharge the battery. After several hours, it showed an error code 'F01', indicating internal cell short. I tried to charge again, and it seemed at least it was charging.
Today I brought the battery to my car. Put it in, and it started at the first crank. I drove 20 miles to get home. No problem. Even the headlight was on. No battery light in the dash. Seems to be ok.
When I got home, I used the same smart charger's alternator check function. It showed the alternator was shot. I tried several times with same result. So I decided to recharge the battery to compensate the power I used while driving home.
After a while, the smart charger was showing it was charging at 12.1V. I disconnected the charger, use the multimeter to measure the voltage on the battery. 13.4 V. I then started the car, measure the voltage agaion. 14.5V. I did several times, stopped the engine, measured, started the engine, and measured the voltage. I could repeat the result. Then I used the smart charger, this time it showed the alternator was good! :shrug:
I took the car out for a spin. Roughly 5 miles and I got home. Before I stopped the car, I measured the voltage while the engine was running. I believed this way I could get the ALT voltage. Guess what, 12.1 V. After I stopped the car, it's 12.3V. And the smart charger this time said the ALT is no good. I was like, ????????
I recharged the car again. I could not get the 14.5 V from the ALT any more. But earlier I was able to and things were green at that time. I cleaned the battery connectors. Although it seems to be the ALT, but I still hope I could get it to show otherwise.
I haven't checked the 5th fuse and the megafuse. Should those be my next steps? I appreciate any help!
THANKS!!!
Short version:
Full version
Hi guys,
THANKS!!!
