97GLblack
what is needed to add the stock headlights to a pre-98 without?
pre98 has a plastic piece that is bolted in to fill the fog light holes. no need to change bumpers. :shrug:First thing you'll need is the front bumper cover c/w nacelles....
You don't have to use the stock wiring set-up. You could just wire it up from the battery. I have mine set-up with a relay so they come on with the headlights.
+1 as well, although mine are relayed off the corner lights so it looks like i have the fog light mod done+1, I have mine setup from the battery with a relay so they come on an off with the car (pending the out of sight switch underneath the steering column is on.) That way I never forget to leave them on when I turn the car off. And I Can drive around all cool with just fogs on
