My latest brilliant move...
Replaced the 02 sensor [an incredible chore, with typically everything as tight as a gnat's ass], thanks to GoldenTour's how-to. The upside: no more P0133/P1131 error codes. However, ran into a bit of a problem as a result of the fix: while using the tire pry bar to pry the wire harness up the bar slipped and slammed into that constellation of colored vacuum hoses [red, green, white] behind the EVR/EGR valve. [EXPLETIVES DELETED] Ray had it right...those little things will snap in a heart beat! So the new downside: P0174/P0171...massive vacuum leak. So I bought some new vacuum hose from NAPA and will attempt to put Humpty Dumpty back together again. Just a quick question:
Assuming a snug fit with the new hose over the old, will this give me a decent 'fix'? Is any type of sealer needed/recommended? Any other suggestions?
Thanks again for the feedback.
