I have a 96 contour SE 2.5L that I am fixing up to drive for a few months. I was having a little fuel leakage from my injectors so I did the UIM/LIM cleaning + valve cover gaskets, etc. Ran into a bit of a problem when I went down to the dealership for a set of O rings + fuel rail seals. Aside from the $100 price for 6 seals and lower O rings :crazy:, Ford has apparently obsoleted the upper O rings. I haven't been able to find a set anywhere locally or online. Apparently Delco makes a TBI kit for $50 (PN 405090) which has the fuel rail seals, O rings and UIM gasket set but I can't find that anywhere either. Does anybody know where I might be able to get a set of injector O rings/seals or the Delco TBI kit for this thing? I checked the injector spray pattern by turning on the ignition with the LIM removed but the injectors installed and they seem to be otherwise OK, aside from the O ring leakage. Thanks.
