Unless you have solid piston rings, which you don't and don't want, and a perect seal when the valves shut, then no, you can not completely eliminate blow by.
What Josh is selling won't have the effect you're looking for in regards to blow by.
It helps to seperate the oil that may get caught in crankcase vent tubes and from being redistributed to the incoming air charge for the cylinders. If you'll notice that some UIM/LIM are all gummy from deposits, it can be attributed to the recircualtion of exhaust gases (from the EGR) and PCV system
