and tell me if i need to bully around with this code P0420 situation more than i already want to?
You see... after reading tons of info on here, i am more lost than finding a solution to take on this.
To start out, i don't have the cash for headers, second, don't have the time to futz around with a set of used headers that could become a problem later on if i replace mine and third before i install MIL's or headers or else could anyone with the same problem before and similar stock setup test my car out and see if there is any drop in engine output/performance?
My car is a 1999 CSVT, 75k, well maintained, the only problem is the P0420 code and it is about the firewall cat...all new plugs/wires, new oil, IAC/EGR valves just cleaned, new gaskets, good fuel injector in it, good gas in it, new fuel filter and the car is not beat on (if that matters).
The only mod is a SRI, which is like two weeks old...this cat failure problem is about 6 months old now...and now all three sensors are replaced and nothing.
Also, i hear that the Denso o2 sensors are better than Bosch at reading the levels of the exhaust thus could be a problem too...but even with the original ones it gave me that problem...
Man, i am like not desperate but the one thing i do know is that i don't drive like a maniac, don't like to be at the pump so often but i barely get 245 miles to the tank (at 12.25 avg gallons at every fill-up) and fill up again...i thought these were to get close to 300 and this thing did at one point back in March...no codes yet then...
Thanks for anyone who is willing to drive an awesome machine :laugh: I can drive to you, so long you are not in like god knows where away from Chicagolandish area. I am in elk grove village.
