Hi guys. I'm back .. with some more problems.. not good.
I checked the dipstick and there was only a little bit of oil on the tip. This happened at 500 miles. Even though I rebuilt the engine is it common to burn oil the first 1000 miles or so? I changed the oil and filter(at 510 miles) and today(i'm at 890 miles) I added a little more than 1 qt. I checked compression and it's around 170 for all cylinders. I checked around the valve cover and it doesn't look like oil has been coming out from there. I checked the oil filter , no leak. I took the spark plugs out and there seems to be a little bit of oil around their threads. The car is not giving out any blue smoke either. What in the world is going on??
I read Striker2's post :
"As some of you know i had an issue with burning oil (lots of oil). turns out it was the head gasket was leaking oil into the cylinders. apparently there have been some issues with the ARP head studs not staying torqued if you dont remove the coating from the threads at both ends, the underside of the nut, and the side of the washer that contacts the nut"
I'm starting to believe that I have the same problem , but I have the same head gasket studs( so there shouldn't be an isssue with the coating)..
I have no idea what's going on.. Any thoughts??
Thanks
Thanks
