Hi guys.
I have a 97' ,Zetec Contour,2.0L,DOHC and would like to turbocharge it. What is the best choice in doing that? I have rebuilt the engine with JE 10.5:1 Forged Pistons (85.00mm bore) and Eagle "ESP" 3-D H Beam Connecting Rods - 5.483".
Since my compression went up , how much boost can I put in it? I heard from a couple of friends that you need a lower compression to run about 20PSI.
Can I run about 10psi , or is my compression to high for the stock valve cover??
