I've removed the nut and the bolt from the knuckle but I'm unsure as too how to separate the lower ball joint from the knuckle. I don't want to use anything that is going to destroy the boot like a pickle fork, so how do I separate it?
I'm used to Honda's where the ball joint is in the knuckle and goes down into the lower control arm. I can just take a small sledge and hit the side of the LCA and after a couple hits the ball joint will just pop free, nice and easy with no damage to the boot.
Any tips or tool I should use would be greatly appreciated. Thanks
