I know this is the wrong time of year to ask... but i'm trying to fix my 99 SE up.
I put a hole in the radiator when i ran it off the road about 8 years back. I had a ford dealer perform the repair and they replaced the radiator and the A/C condensor(?) also (the thing with fins behind the radiator).
After two years the A/C stopped working. That was about 4 or 5 years ago.
I'm hoping that fixing the A/C might be just a matters of replacing the current fittings and recharging it, but I don't know much about A/C and was wondering whether letting it sit for so long could be bad for it.
I've done a successful UIM/LIM rebuild recently, so my skills are OK.
Is it bad for an A/C system to remain uncharged for a long period? If so, what problems would this cause.
What kind of equipment would I need to rent/borrow to recharge the system? I'm thinking that I'll need a vacuum pump and some gauges at a minimum.
Could this problem have resulted by the Ford tech not tightening the fittings correctly? If so, what's the best approach to fixing this? What should I check first and how do I check it?
