kw8z3boi
I was wondering is it my head lamp or all contour light is not that bright at night? I got my lamp brand new about 8 months ago and it wasn't that bright at first.
So this is what I do, the 9006 low beam connector (brown), cut the little two tab with the toe nail cutter, put a 9005 bulb in there and that's it?
What do you mean when you said "i warn you not to buy "high wattage" bulbs like 80W(low) 100W(high) as they can melt your wire harness." Like don't get any bulb that has 80W or higher for the low beamn and nothing higher than 100w for high beam?
one more question. What's a nice set of bulb that have a nice blue look? Or purple if it look like those BMW. I think the purple you have to have projector right?
IMHO the light spread was/is better on my pre98 than my SVT with the same set of HIDs. The flutted lens helps to focus any stray light which makes the whole pattern brighter. Once i get another HID kit (i took the one of the zetec for the SVT since its my DD) i will see if i cant get some pics of the 2 of them parked next to each other pointing at a wall.they prob. have HID lights. you can put them in your tour as well. although if its a pre98 the light spread is going to be horrible b/c of the flutted lense
