Tony about summed it up, one of my bolts was quite rusted also, and I too did it carefully, afraid of breaking.
Also I work slowly! Had to sand some of the ends of the new mount to get it to fit in, the rubber covering it made it too wide. The clearance at the bottom of the transmission increased slightly so there is maybe 1/8 or 1/4" to the nearest part of the subframe, frankly not that much difference from the old mount, but it did reduce idle vibration.
Edit: Just been under the car, see rear mount impossible to replace without removing engine, right?
My front mount near the radiator looks generally ok, a little space at the top inside the mount between the rubber insert and the metal frame, but I don't know how sensitive these things are to any little change. I guess I might as well change it and see what happens.
Tell me about the other mounts, how hard are they to replace? I'm beginning to think my 2200 rpm stutter/miss is really one of the other mounts, as my idle in gear stutter was cured by this mount.
Mike
