98TredSVT
I cut these because I was a retard when installing my suspension and they got tangled up. If I just twist them back together and tape them up real good will it turn the abs light off and allow them to work again?
You have to pull out the rear seat cushion to disconnect them.... Where does the end nearer the front of the car disconnect? I see it runs into the frame of the car but then to where after that?
I'm not 100% sure on either of these, but the I think the wire ends right at the ABS module. And the sensors should be universal across all years.
