Fan motor problem
trhlz1222
Holly Springs and Parish
recently my fan motor for the heat and ac in the car has been blowing the fuse everytime i put it on the highest speed. then it started to cut on and off while it was running. Now it wont run at all. the fuse is still good too. how hard is it to replace the motor or any other possible problems?
dont mean to bring this back up but i finally got time to get to the fan motor and well it works fine. all the wires and such that was suggested could be corroded looked brand new. the fuse is still good. last thing i can think of is the motor switch. how do i get to it and wat other things could be wrong?
that the last option that could be wrong?
If you are asking what other things could be wrong, it would be wiring. You need to test wiring from battery to fuse, fuse to switch, switch to blower motor.
