Just Purchased a '97 Contour with a 2.0 Zetec and auto trans, had a bad timing belt adjuster pulley.
Just got done changing all of that, seems to run OK. The car has been sitting for about 2 years.
It is having a problem shifting out of 1st under full throttle. Shifts a little late at moderate throttle. I you are running at about 35 mph or so and step on the accellerator, it will kick down to first and bounce off of the rev limiter until I back out of the throttle a little. It does have a bit of a clunk to it if you give it a little throttle while cruising at 30 or so.
I did change the trans fluid, the old fluid looked pretty good and was not burned. There are no funny noises.
I hope that after I get a few more miles on it it may clear up.
Anybody have any thoughts?
Thanks in advance!
Scott
Thanks in advance!
Scott
