trail brake
New CEG'er
- Joined
- Oct 30, 2007
- Messages
- 14
Hello all. I've been lurking here and reading through some of the links to old forums until I could post.
I have a 1990 Miata and have been tossing around the idea of using a Duratec 3.0 for an SM2 autocross car. On paper it sounds like a good marriage because of the aluminum block and decent torque potential. In N/A trim a Miata could run with a minimum weight of 2200 lbs and that should be no trouble with the 3.0l. The shorter block length and potentially lighter weight (does anyone know what a long block weighs?) the balance could end up at 50/50 or better depending on set-up.
All that being said, after reading around here I get a little nervous about the Duratec because it looks like most people who do 3L conversions to Contours do so due to spun bearings. I see another thread here that weargle wrote where his new 3L has spun a bearing too. Is this a weak point to the motor? :shocked: Is there anything that can be done to prevent the problem form occuring during build-up?
If I build one I'll want to be able to wind it up during runs. If I'm always worried about spinning a bearing though I don't know how much fun the car would be. Let em know your thoughts.
Doug
Doug
