Tomato
Hey guys,
I realize this is really not the appropriate place for this post, but seeing as I cannot post yet in the other areas and most of you EGL guys are in my area I figured it couldn't hurt.
I've been having some electrical issues as of late, I've used the search extensively and still can't find the answer to my problems. Maybe I'm not using the right search criteria.
I'll start with my problem.
Happened the day I picked up the car (go figure) Sitting idled for an extended period of time, car decides to shut itself down, wipers go off, then it starts right back up. Precursor to this was flickering dash/head/interior lights. It did this twice (about a month ago) and has not done it since. However I do notice that I have flickering lights whenever the engine is cold, and I've even had it a few times when it's warm, but it's very evident when it's cold. Also past about 5500RPM, I'll get a flashing Charging System light.
I've tried to diagnose but no solution yet.
Did the MM Alt Test.
Battery comes out good and 12.X volts.
Alternator a constant 14.5 volts across the entire rev range(even past 5500 when the light if flashing multimeter still shows 14.5). This was tested at the battery posts.
Tested the resistance on the MegaFuse, that pans out good too.
The alternator in the car is an OEM Ford one that was replaced about a year ago. I've read of the brushes floating at high RPM's when it's on it's way out, but the output was still 14.5V in the rev range where the problem occurred.
As well I've read up on the "Golden Tour" wiring fix. From what I gathered in the various threads this is used to correct an constant on Charge system light at idle, and flickering in the higher Rev range. Is this true or have I misinterpreted what I read?
I've also seen the "Big 3" upgrade a few times, which I can only assume is upgrading the grounds?
Last but not least I came across a post quote a TSB concerning Oscillating at idle in cold weather which could cause the dimming lights. It recommended a wire upgrade due to increased resistance in cold weather. Anyone familiar with this?
With all that said any help would be most greatly appreciated.
Thanks,
Al
Thanks,
Al
