O.k.... I got the car started. Interesting though, I opened the hood and then cranked it. It turned a couple of times and I put the pedal to the floor like you had suggested and VROOM... However, the interesting part is that after it started, I noticed the accelerator cable was above were it should be. So when the hood was closed, it was resting on top of the cable. I thought that may have been it. But it would not have started yesterday. It was running rough and the lights blinked a couple of times. (waiting on the harness) I checked the spark plugs and they looked worn. So I changed out the plugs and wires. When I was disconnecting the negative cable, I noticed a breaker sitting on top of the battery. :shrug:  I opened the breaker box and could not figure out where it came from. Thinking the tech may have changed out the breaker for the a/c and left the old one there, when I had the a/c fixed Monday. I did notice that one breaker was not plugged in all the way. Pushed it down, completed the work and put everything back together. Started the car and it ran very rough. Let off the gas and it stalled. Got it started again and kept the rpm around 2k. Let off the gas and it stayed on still running a bit rough. But here's the kicker... Turned on the a/c... no cool air. :crazy:  So I'm not sure what to think now. Any idea's?
