my98SVTturbo
I didnt find much while searching but what do you need for a sub in the trunk? do you need a copacitor or what?
how do i tap the power into the battery if im installin somethin that needs it.
My whole setup is for sale in the classifieds...onder:
But, seriously, all you need is power wire to the amp (don't need a ring clip necessarily, but it's recommended), wires from amp to subs, ground wire from amp to frame, and a remote wire from harness to amp. Then subs and amp .
You forgot the RCA's. :crazy: Since our cars are unibody, I opted to run an additional ground wire from the battery terminal to the amp. Yes, I still kept the smaller ground to the body, but it's a little better grounding for the amp.
DANGIT. Yeah, you need RCA's as well. There is a pre-out on the back of the deck, and they run from that to your amp. These need to be run AS FAR AWAY FROM THE POWER AND GROUNDS AS POSSIBLE. MAKE SURE THEY DON'T CROSS PATHS. And make sure the RCA's are protected so they don't by accident ground. This will cause severe adverse effects...
Only if you're doing a 4-channel.... subs it doesn't matter, you can run them all down the same side if you're doing subs, if you add a 4 channel later you can run it on the other side...
I'd run them down different sides anyhow. When I did my first system I'd get a nice thud when the power wire charged up and the amp turned on.
the power wire doesn't charge up, the capacitors in the amp do, that's what causes some amps to thump when they turn on.
Most high quality amps delay turning on output end of the amp until after the caps energize to avoid that.
Power wire doesn't induce audible noise in rca's either. If it did so would the chassis of the car. It's an old installer myth that just won't die.
that's ground loop noise, not EMI.They do if your grounds are at different potentials... hence why they recommend running signal RCA"s 18" away from high current wires...
So you in-fact don't know.
There is infact AC that flows along with DC in a vehicle. Hense induced noise and things.
There is also magentic fields as well that can induce noise.
AC voltage is produced by the Alt then is rectified into DC. The carrier wave is Dc but there is a AC present when the Alternaor is chargingLogically - I disagree. Where does this ac voltage come from? The alt produces DC, the batt obviously produces DC. I mentioned the likelyhood of a slight ac component between the alt output and battery, but the battery will filter that almost entirely.
Really? interesting I guess I should be out of a job. Magnetic fields do create noise and Massive amounts of noiseMag fields in general aren't noise inducers.
High current mag fields that vary drastically in voltage at an audible frequency are noise inducers.
Avoid the alternator and the blower motor when routing signal wires.
What else do you suggest?
there's maybe a volt fluctuation, tops, peak to peak, usually much lower. If there IS more than a volt, chances are the alt is defective.AC voltage is produced by the Alt then is rectified into DC. The carrier wave is Dc but there is a AC present when the Alternaor is charging
funny you should say thatI suggest you to figure out what your talking about before posting on here. Becuase you are off base.
