69Boss302
Has mile high skills
the basic info: 04 Taurus 3.0 (23,000 miles)going into an E0. keeping the SVT intakes only. I'm not swapping the cams or heads.
Questions or concerns...
I can use the 2.5 oil pan without any clearance issues on the Taurus block, correct?
I reuse the 3.0 timing chains and sprockets because I'm not swapping cams, correct?
Only the pulse wheel changes for this, yes?
Should I be able to use the standard Clevite rod bearings on a 23,000 mile motor?
And lastly, the motor I'm pulling out has a lot of sand and/or metal shavings in the radiator juice. I am sure that is all the way through the whole system and in the heater blower. Can I flush this out without having to take it to the dealership?
That's it for now.
EDIT: one other thing, does anyone know the difference between the 04 Taurus valve cover gaskets and those from the 2.5s? Fel-Pro has different part numbers. I know I need to use the 2.5 covers but I'm wondering if there will be a compatability/sealing issue.
MORE EDIT: I forgot that I have a brand new OEM diff that I bought to do "some stuff" to it for an experiement. Being that this car is high mileage, would it be a good thing to swap out the old diff for the new one? And do the shift forks too while I'm there and for the fact that I have them as well. Just remembered I have those as well. BTW, I'm not going to be doing that experiment anymore.
That's it for now.
