swissfrank
New CEG'er
Perhaps you should grab a cup of coffee or something stronger before reading on... at this point, I too am in much need of a case of beer all to myself.
Up until yesterday my contour had been driving like a fine european luxary car, lol. Replaced all engine and transmission mounts, tranny flush, water pump replacemnt, timing belt replacement, replaced serpentine belt tensioner, and belt, among many many other things. Almost every last peice of my car has been service or replaced within the last month... It also handles like a dream but Spent a small fortune on 225-45/16 and the Koni Suspension Kit. This contour has been maintained right from the begining.
Now yesterday it stalled on me in traffic, and after much hesitation to start I managed to limp it to my friends place (about 10 blocks). Opened up the hood and the Cat was glowing red :shocked:. hooked up my laptop and pulled the 1 - DTC and it stated my ignition coil has failed. Was just going to replace it until i noticed a few other things...
I moved the main wiring harness by fluke and the car started to run perfectly fine again:shrug:. So i opened up the harness to inspect it and it looks like Ford already been in there heat shrinking the **** out of it.
I should mention it rained pretty hard the night before...
Anyway, I then noticed when I leave the Ignition to the ON position there is a loud electrical hum from the engine area. Unplugged the Ignition Coil as I suspected that to be humming but the hum continued. I then figure my ABS module was humming as I now also had the ABS light on after the rain, so I went into the Power Distribution box underneath the hood and pulled the ABS Relay, still no affect. Inspected the rest of the relays and found one that was hot as hell! Pull the relay out and the hum went away. I cross check what this relay was and it was the R11 location (PCM Module Relay). I though the relay might have been fried so i switched the horn relay and the pcm relay (they are the same) and horn still works fine and the hum was back again when i replaced the new replay in the PCM location. Unplugged the MAF and IAT just in case, still making that noise.
After closer inspection I noticed that it came from the MLPS area, so suspecting that, I unplugged that as well, and it was still humming. Then I pulled the wiring harness off the Tranmission and it FINALLY STOPPED.
I also noticed earlier that day that If I would Redline the Engine the Charge Light would come on, which I never had happen before up until today. The Serpentince Belt is about 400km old and no slippage on it at all (no glaze). The Tensioner was also replaced at the same time, and so was the alternator.
I have no idea what it going on, Shift solenoid shot? Huge Electircal Problem or what? I should also mention that the tranmission has been working seamlessly, great quality shifts all the time, and absolutley no, shakes, rattles, shudders, and no harsh shifts or anything of that sort. The Spark plugs are also new(NGK PLATNIUM) and I tested the resistance of the plug wires (BOSCH) and everything was normal, for 1 year old wires. I also triple checked that they were all seated properly.
As a student this is going to be a Big Blow for me as I already spent a fortune on this car, that I love i may add, and it rewards me with nothing but headaches with the electrical nightmare that I believe this to be... Hopefully someone out there can be of assistance to me, I think im screwed, and I would hate to have to say goodbye to my contour. But I dont have the money to take it to a dealer.
Thanks in Advance,
Frank
1996 Ford Contour
2L K&N Drop in - AutoBox
225-45/16 & 4 Wheel Vent Discs
With Koni Suspension Kit
Pics on request
Thanks in Advance,
Frank
1996 Ford Contour
Pics on request
