Help.
Help.
ok. Well I finished the wiring harness job but I obviously screwed something up. When I put the key in with the door open, I hear a relay clicking and none of the internal lights are on. Plus it wont start. Wont even turn over.
I think I screwed up one of two things or both.
Edit: "This is not the problem and this description is incorrect, see next post"
1) When I was plugging in the connectors on the bottom of the auxilliary fuse box, I might have put some of them in the wrong place. I dont have any pictures of the inside of this box to know where the connectors are supposed to plug in. Of the five connectors, four can be plugged in the "wrong" place. There are two interchangeable sets of two connectors, four total. Ok that was confusing, there are five connectors total, 1 unique, 2 type "A", and two type "B". I am not sure that I plugged all the type "A" and type "B" connectors back in the correct places. For further clarification, This is underneath the rear part of the aux fuse box, the one without the 60 and 80 amp fuses, without the relay spacers.
2) When I swapped out the "T" bar power supply that connects to the 60 and 80 amp fuses. I am not sure that I put the wires back correctly. I know the "T" is in the right place, but the other 6 power supply wires, I am not sure about. For some reason, I dont think this would cause the problems I am seeing. I mean, this is just power supply, so maybe power is running through the wrong fuse, but it should still be getting there.
In short, I need some help. If anyone can make me a map, of where the white connectors go, or where the black connectors go that would be awesome! Or a picture would be great too.
