How to on reverse polarity of clock.
Thats cool I can wait till Friday for a how-to. I have been wanting to do the reverse glow clock for a while now. :drool:. Did you do it yourself or have someone do it?
Sorry man but i hope its not to late on the how to do the reverse polarity mod on the dash clock. This makes the back ground light up and the numbers are black. Hope this helps any others out there.
First thing is to take clock out of dash by using a small flat head screw driver. Careful not to scratch the dash (I wrap the tip of screw driver with a cloth so it doesn't scratch my dash since i have mine painted.) Just push tab to unplug harness.
Next with same small flat head screw driver just pop out each tab on each side of clock and then pop the one in the middle. Be carefull not to pry to hard or you can break the plastic. Put Plastic back cap aside.
You will now see the interal circuit board just push two white clips on each side out and the board will come out very easily. Put aside.
Next remove a white piece that just slides out. Put aside.
Next take out the screen that is attached to a black rectangular rubber piece. You will also see a white plastic thin cover just put aside.
Now is the actual part that will change the clock to work backwards. There is a plastic cover that goes in front of the glass display that needs to be removed. (Not the back white sticker) It is in the front. Just be careful and pry it off. It will be stuck with glue so just wipe of stickiness with and any degreaser. Soap worked for me. Once cleaned from its stickiness turn that outer cover around and you will notice when you put it against the glass display that it does not turn dark on the display. Now it will work backwards.
Now it is just a matter of put it it back together.
I did not glue that outer cover to the glass display but i guess you could.
Be careful when putting it together to face the display out right and fit the black plastic rectangular piece against the side that has several lines going down and that the piece fits in the groove of the glass display.
The rest should be the above steps in reverse and you can't really put anything wrong since it fits one way.
Well i hope this helps people. If i have said anything incorrectly just lit me know. I didn't the technical name to all the componets so i hope you understand.
