Ronan
For no reason one day, my IAC valve started to leak around the blanking plate, sucking air in. I replaced it, & the new one did that too.
Someone on here said the throttle hang fix can cause that to happen. I am running the svt t/b and checked the optimum sizes for the oriface. I have fitted these new sizes, and its still not working. If I fit an orifice with a hole too big, nasty throttle hang remains. If I go too small the IAC starts to suck again (and when the car is cold the idle is lumpy & it wants to cut out)
I've tried a few different sizes & either of the two effects above come into play.
My intake consists of a K&N ru3530, svt t/b, uim, & a greddy oil/air seperator (removed it made no difference).
Any ideas why this has suddenly happened? The car has been running fine for months with this setup.
Should I reset the ecu each time I try a different oriface plate?
Thanks in advance guys
