I'm guessing everyone on here has had problems with broken fog lights. It sucks, it's expensive to fix. But I found a solution.
Go to Lowes/Home Depot where they sell window stuff. Grab a piece of Plexiglass, 8"x10", it's just under $3. Cut it into quarters (you only need half of the sheet). Then take a piece and wedge it in front of the fog light.
Not only does it stay put w/o any drilling or mounting, you can't even see it. It'll stop rocks and sand, as well as UV. You could also do the same with glass but you'd need a glass cutter.
Just an idea for an excellent fix... less than $3 to protect $100+ worth of fog lights. Plus you could replace it after a year or two if it gets wrecked with the other half left over.
