rollinstylee
I'm trying to install a pressure sending unit in the engine drain plug that is above and directly in between the oil filter and the back of the air conditioning compressor. I have unbolted the compressor to make more room, and the oil filter is off because the oil is drained. I have a 14mm hex socket that I'm using to try and get the plug out, along with a 1/2" drive U-joint and and extensions. I've doused it with PB Blaster and let it sit. Even with a 25" breaker bar I can't get it to budge. My setup is flexing so much I'm afraid to put any more torque on it. How have people gotten this huge plug out?
