MrFord
Ok, I recently changed my wires/spark plugs on my SVT, and it made a HUGE difference... I guess the garage guy was right about the missfire hehe.
Ok, the thing is, it ran great for only a night, and came back to be as sluggish as before. You can feel it badly under 4000RPM, it just doesn't pull, especially compared to just after I've put the new spark plugs.
I did had a check engine after a little while, for a Lean code, but that's about it. I cleared it, and it never reappeared. Now, the car have some trouble to start from time to time, it just crank dry, then finally after the second or third attempt, it fire off just fine, bout you still can feel it not running as smooth, and accelerator reaction is pretty slow, even in neutral.
I had my OBDII reader plugged the last night while the car was running, and under the Status monitor, I realised that the MAF sensor indicates 0.000lbs/ft (or whatever), either at idle, when I'm playing with RPM or with the car off. So I decided to try and unplug the MAF sensor, and to my surprise, no CEL, and for sure, it still read 0.000lbs on the reader. I remember on my Topaz how sluggish it felt when I had the MAF sensor unplugged, and I was wondering if that could be a case of bad sensor, or something else? Normally it should throw a CEL light no? And I guess normally I should be able to have a reading on the OBDII reader for that?
I never thought I'd miss the good old simple KOEO/KOER tests of the EEC-IV...
