:help: Hey everyone. I really need your opinions'. Recently I had some horrible luck with my SVT. I accidentally downshifted from 5th into 2nd instead of downshifting properly into 4th. Needless to say, my 2nd gear did not match well with my current speed and I burned up the crankshaft bearings. Supposedly that is the only problem (found so far) with why the engine won't turn over/run. I really don't know a lot about engines other than just the basic stuff. The mechanic told me that he could put new bearings in, but then at the same time he'd have to pull all my cylinders and rods and then check them, and all this other stuff. Basically it's going to be pretty expensive just to get the work done on my current engine.
I really didn't want to get rid of my car. I love my SVT. So I started looking for other options. I found a place in Tucson, AZ (which is about an hour from where I live) that said they would do an engine swap for apx $1000. I started looking for other used SVT engines on our website. I also called our friend out in Las Vegas, which I've ordered from before. He told me about the 3L swaps.
Basically, I need everyone's opinion about how I should proceed with this. Keep in mind that I'm in the Army, and I don't make a whole bunch of money.... so telling me that I should get a dodge viper engine and slap it in really isn't going to help much. My final goals with the car, after I come back from Afghanistan, are to put a turbo kit on. So keep that in mind when giving recommendations. I'm going for a suggestion that either leans towards getting a ford escape engine and just dropping it straight in, or somehow using parts from my current SVT engine to build a hybrid. I WILL NOT BE DOING THE SWAP OR MODS MYSELF. I simply don't know how and don't have the time. So also keep this in mind because if there is much work involved, I will be paying for all of it out of pocket. Also this is my daily driver, so I would like to stray away from swaps that are complex and take a lot of time to work all the kinks out. Again, I do not know how to read engine codes and tinker with stuff. I need to be able to get in, turn the key, and get to work on time. This is even after I get my turbo kit installed.
Let me know what you think, and if you are a person that likes to build engines and then sell them, let me know that too. If you have any type of engine (ie. stock SVT engine, modded SVT engine, modded 3L engine) please let me know as well. I truly appreciate all of your input. You have no idea how much it means to me to get others' opinions since you've 'been there done that'.
Thanks a million - Matt
HeavenMusic02@hotmail.com
Cell: 913.579.1536
(All help is appreciated)
Cell: 913.579.1536
