i have the pdf files for the clifford ag4 install manual, owners manual, and the intellistart install manual. if u need them, pm me.
i had the ag4 installed maybe 3 years ago. i'm getting some quirks from it like i now keep it in valet mode all the time. every now and then when i'm driving my lights flicker as if the remote start thinks i'm giving it a command via keyfob. hopefully the intellistart manual will let me retrace the wiring to see if theres anything quirky. everything else seems to work fine. but i think it also gets the weird "ghost" commands when the car is off and i have it armed (not in valet)- the alarm goes off and it wont respond to the key fob. very embarassing in public at nite. i never knew why the flickers were happening or what might've been causing them until one day i pull into the driveway and the flickers happened as i was turning the car off. the car stayed on the exact same way like when i do a remote start prep command or a shortstop remotestart (like if u need to run into a store so u can leave the car running but armed). i cant reproduce the results for the install shop cuz they are too random so i had to find the manuals online to hopefully help me trace the wiring
the alarm is great but it has lots of wiring. i think the shop tried to use a data pats bypass but it wouldnt work so they used a dei pats bypass 555f (i think), it uses a pats key in the box. take your time doing the install and double check your wiring as your progessing.
