Okay, the breakdown according to me
MarK: Maybe you'd like to reply as I don't believe this thread has been properly answered yet (IMO). If the 2.5 crank has a harmonic problem, doesn't it make sense that the 3.0 would not as the crank is a completely different animal?
This is not to imply that adding a DMD wouldn't smooth out the engine, but I'm specifically asking about damage to bearings and the crank from harmonics.
Anyone care to address this specific issue?
I don't think that is an issue at all. There has been no evidence of harmonics issues with the stock 2.5L damper. THe bearings problem is most certainly an oil related issue rather than a harmonic damper one. Part of the information that supports this is:
-we've had 2.5L with DMD have rod bearings fail exactly the same as with a stock damper.
-The 3L escape motors have the exact same damper as the 2.5L contour and so far have NOT had the issue.
-Ford revised the pan several times, though I personally don't think this was the answer/solution. But it didn't hurt to try either.
-Ford used 3 oil drainbacks on the 3L engine and this may be the best improvement
-the DMD has been a hit or miss item on some engines. Some 2.5L/3L engines are so smooth on the stock damper that a DMD has had no effect. Some have benefitted and had a reduction in harshness.
So to sum up, if you have a bit of NVH, get the DMD and try it out. Otherwise save the weight, time and expense.
For the oiling issue we've found the following opinions with some circumstantial evidence to back them up:
-Add an extra quart of oil (6qts). oil doesn't drainback as fast on the 2.5L from the head and traps more of it leaving the pan almost empty at high rpm. Combine that with the transfer (Slosh) of oil that stays in the head to the sides during cornering and you can see what might happen.
-use the updated oil pan. This is supposed to help. I think just taking and drilling a couple of extra holes in the stock pan's splash shield at the edges will suffice though.
-Upgrade your rod bearings in your Duratec with Clevite77 Tri-metal. They are hands down better than the basic cheapo all-aluminum alloy bearing used by Ford. The stock bearings are harder and have no way to absorb particulates and are more likely to generate friction if the oil pressure ever does drop. This is a 100% must do IMHO if you are rough on your engine.
- Run a different weight of oil. There is a RANGE of multi-grade oils that can be used in the engine based on temperature. To my knowledge the majority of the bearing failures are on the thinner oils. THe thinner oils are only recommended for cold climates and for better gas mileage. I personally feel that 0.3mpg improvement isn't worth the reduced protection.
My recommendation is to use the temperature vs. Oil grade scale found in the owners manual and run a weight of oil based upon the time of the year.
In AZ I always ran two different weight oils from summer to winter and I still generally follow this practice.
For cold climates I would use a 5w30 and for hot climates a 10w40. I've even used 20w50 on my stock 2.5L and NA 3L in the summer and I have perfect bearings with it no matter the hard driving. I've run 10w40 on all my 3L turbo engines in summer and 10w30 in winter. I've had the opportunity to inspect my bearings multiple times and they have always been in perfect condition despite producing power levels greater than 2-2.5x stock output.
There are people on here that have slightly differeing opinions on the oil and on some of this but I don't think anyone is greatly different, and no once can absolutely refute this summary as wrong. So is that broken down enough for you? lol
