Mike61
New CEG'er
I have a 96 4cyl Contour with 105k miles that recently developed a problem with cold starts. Details are:
I had disconnected the battery to clean the sensor, and to replace the IAC and O2 sensors. Each time the car started on the first try when the battery was reconnected.
Any help would be greatly appreciated. This is the wifes car, and she wants to go back to driving it.
Thanks, Mike.
- Batttery and starter are fine, the engine turns over with no problem.
- Takes 1 to 2 minutes of of hard cranking while pumping the gas to get the car started.
- One started the cars runs fine, same as it always has.
- CEL light off, no codes in the computer (according to Autozone)
- Once it has been runing it will restart with no problem swile still warm.
- Downstram O2 sensor, and IAC valve replaced, Air flow sensor cleaned after problem started. (All by me) None of these had any effect.
- Problem goes away for 1-2 days when the computer is reset.
Thanks, Mike.
