I'd just clean out as much of that peanut buttery goo as you can and run it hard, but start saving the cash for a new longblock. Maybe you'll get lucky and never need it. The longer there's water in the pan and on the bearings, the more damage is being done. Take the car out and burn it all off!
One unfortunate thing about that kind of bearing damage is that you couldn't get away with just replacing the bearing shells themselves. The journals would likely be scored and pitted from the corrosion, so you'd looking at some machine shop work to regrind them. Top end doesn't really require so much lubrication and probably is just fine. You should probably take the valve covers off just to have a look.
As far as the rods, just check your compression again. If the rods were bent, it would alter the compression ratio (and psi) in one or more cylinders. This would be the case even if the distortion in the rod wasnt visible to the naked eye.
Adam,
I'd run it as is and call it a day. If it spits the motor out later on down the road, so be it. Deal with it then. Don't go on a wild goose chase at this point over what might be wrong.
Not sure what to say on the vibration though if it wasn't there before this little incident.
Rick
mcgarvey,
thanks for the advice.
When I stalled I was going slow and pretty low rpm. I just let it die, did not try to apply more gas to keep it running. I did not try to restart it.
Pushed it home (in a massive thunderstorm, in a suit). Let it sit for 4 days. Water that was in the cylinders seeped around the rings and into the pan.
Disassembled to remove any standing water in intake track. Turned it over with no plugs to clear any water remaining in the cylinders. (there was none) Re assembled and ran at idle for 5-7 mins to steam out any extra moisture.
One day did pass between running it with the soft server and when I changed the oil. This would be the only time the water infused oil was left in contact with bearing surfaces.
Dropped pan cleaned as much of that crud out as I could. Fresh oil.
I have driven it enough now to remove ALL moisture. H20 never sat on the bearing surfaces so hopefully no corrosion and such.
I will definately do another compression test to ascertain if it has been altered.
I wish I could just swipe my VISA across the dash and $400 later have a new motor. Its the damn time and effort that kills me.
Also, thanks Mike for engine help offer. I already owe you quite a few beers and a real ride now that (most) kinks are worked out.
Agreed. You did you best to get the water out of everything. Put new oil in it and do a compression test. Don't post anything else here until you have done so. Otherwise, it's just speculation (drama).
Alright, compression test complete
210 210 209
209 192 193
This was on a warm motor. Last time I compression tested all were at 214-215 so compression is down across the board and down quite a bit in two cylinders.
My estimation is that is do to some rust on the rings or cylinder walls during the days it set with water in there.
Would a warm motor make a difference over completely cold? I would assume due to expansion that a warm motor would yield higher results? I did drip a little oil into one of the 193 cylinder and retested with 215 as a result. So, thats where it stands.
Maybe, just for the hell of it, I will run another test Saturday with all plugs removed.
Nothing to lose but my time.
and if there's anything to catch you'll catch it, no downside.
Thats good... Your homeboy Confucius tell you that one?
