I have a 1998 Contour SE with 150,000 miles, it has a 2.5 V-6 and an automatic transmission.
The first symptoms of the problem started a while ago. I originally thought it was a transmission problem but now believe it to be a fuel delivery problem. I have done a lot of research mostly on this site and found little information other than the possibility of a bad idle air control valve. I haven’t had time clean the IAC. Furthermore, I am hesitant to clean the IAC because I don't know what else to look for if the IAC doesn't fix the problem. Any thoughts or suggestions would be helpful.
The problem is a stall or possibly a miss usually under acceleration. The RPM's do not drop but there is a hesitation in the cars speed and an annoying jerk.
As I said earlier the first symptoms I thought were transmission related. The only time the "jerk" occurred was after the car was up to speed when I give the car gas, usually before an up shift of the transmission.
However, the problem has become more frequent.
There is no real pattern to the jerk other than acceleration or possibly when going up a hill at a cruising speed usually between 1/8 and 1/4 throttle.
The car cranks, idles, and usually cruises at a steady speed with out a problem.
Also there are no new check engine codes. The Lean O2 2nd bank and no EGR are there, but are old codes. The Lean O2 has been a problem since the car had 35,000 miles its been to 4 different dealerships and had over $1000. spent on it and the problem still exist. This isn't a code that I am taking into consideration since it has been present for the last 115,000 miles. Also I disconnected the egr.
I will try to clean the IAC today, however I currently live in an apartment and they are strict on the parking lot policy. If the IAC doesn't cure the problem I will probably wait till next weekend and head to my parents house were I keep all my tools and there are not restrictions on auto work.
What else could the problems be? my thoughts are
1. bad Throttle Position Sensor
2. bad coil pack
3. some sort of injector problem maybe electrical
I don't think its a bad fuel pump because the car idles and cruises fine.
However, I haven’t done a fuel pressure test.
Thanks for any thoughts or past experience stories.
2. bad coil pack
