engine/tranny mounts
98TredSVT
Plainfield, IL
What is the suggested fix for excessive engine/tranny movement? My car has 120k and in any gear if I am cruising and just give the gas a slight punch it feels horrible and you can feel the engine and tranny jiggling around while the car doesn't respond immediately because of all the play.
Have pole120 fill them , or if you cant afford that for now, get a Energy suspension front mount insert, that helps a ton! But make sure they arent broken first. I have yet to get mine filled yet but I will be, I could care less about road vibrations.
ps and the proper name for the tranny mounts are roll restrictors
Check your actual trans mount on the drivers side fender, It sounds like your bolt may have broken in the mount, its fairly common.
