amsra
New CEG'er
My 96 GL ATX has a factory cassette radio in it and I wanted to replace it with a factory CD radio. The power portion of the wiring harness is common to both radios.
What I assume is the speaker harness is not. The old cassette radio has 8 spade terminals that run parallel to the spades on the power harness, that the harness plugs into, but the CD radio has 3 seperate areas. The middle has 8 pins (2 rows of 4 that run vertically). The top area has some sort of adapter plugged into it and when you unplug the adapter there are 6 pins (2 rows of 3 vertically). The bottom has 2 pins.
I was hoping this was going to be an unplug one--plug in the other sort of deal. I guess nothing is ever THAT simple.
Is there an adapter from the factory harness to this radio or do I need to change the plug on the harness? What is the easiest way to do this? I'm not a big audio guy, I just want to play my CDs when not listening to a ball game.
