ok this mornings update. The tick is gone. We went out this morning and fired the car up. Started on the first try. It ticked for about 3 seconds and then it went away. My father figures it was air stuck in a hydraulic lift that finally worked its way out. The engine sounds very strong. It went right to a high idle and after about 5 minutes came right down to a normal idle and was running perfectly.
So we rolled the car out on July 29th and working just about every weekend, mines the first weekend in August and one day last weekend we where able to get the motor installed and running and the car can move under its own power.
Next up is to get a working parking brake so that we can safely move the car around under its own power. This way we can move it into the garage and start working on the suspension and brakes, and the remaining body work that needs to be done, which is re-installing bumpers, etc onto the car.
