this weekends progress included getting the exhaust installed, getting the interior buttoned back up after installing the shifter, finishing the clutch linkage, installing the radiator and hoses along with the carb, air cleaner and a few other things. Electrical is about ready to go, just need the alterntor/battery ground and a distrubutor and that is set. On the fuel side we need to finish installing the fuel line byt installing the retaining clips and connecting the hard line to the tank and fuel pump. Other things that will get done this year, install drive shaft and get the parking brake working. Brakes will come most likely over the winter or next year. Again the goal is to get the car running then make it driveable. Next sunday we will be swapping the original front springs back in as well as installing the shocks on all four corners.
