I was wondering if anyone had information with regard to the ride height of our '97 Contour SE with the 2.5l V6 and automatic trans and about 80,000 miles. I started comparing it to other Contours around and this one is considerably lower than others. I actually like the look but since I'm getting a lot of suspension noise I know it is time for some new parts. This is a daily driver and that includes winter and then ground clearance becomes an issue. The previous owner ripped back the mesh cover on the exhaust flex pipe so I know clearance has been an issue. I measured the bottom lip of the fender well at the center line of each tire and got LF (left front) 25.5", RF 25.6", LR 25.1", and RR 25.4". Is this normal? My spring code on the door jamb sticker DZZW and the front springs have a sticker with a DZM and a 94BB on them.
The car has a harsh ride rattles over bumps and a clunk when turned hard left at slow speeds. I climbed under and found the left rear spring was broken and right tie rod shot which explains some of it. The struts appear to be original as do the springs.
So I'm planning on new struts and at least rear springs. I originally planned on Gabriel replacements struts, and aftermarket springs like Moog or McQuay-Norris since the cost is pretty reasonable. But I see that Ford lists both the struts and springs as being different for an SE. Aftermarket stuff covers several applications. Has anyone had any luck with the aftermarket stuff or should I stick with Ford parts? I have a feeling the aftermarket strut/spring combo will lift the car which is fine if it doesn't look like a 4x4. After ready other posts I don't see a big push for Motorcraft struts but I do some using Ford springs. What about the Gabriel struts and Ford springs. The big thing is getting rid of the noises and harsh ride. I'm not hard-core on performance (OK, not when anybody is looking) but I want a good balance between performance, ride height, and cost. Also do I need to replace the front springs?
Any suggestions would be helpful.
Thanks, Joel
Thanks, Joel
