PurpleMystique
Here are the pictures I took of my day of fun. Sorry, but all I had available was my cell phone.
Here's one vacuum line pulled:
Here's how I rigged it up. I bought some aquarium tubing from wal-mart and wrapped duct tape around the end to make it fit snugly in the hole:
And then I used a C-clamp to regulate the flow.
It went in smoothly but there was a lot of toxic-tasting smoke coming out of the exhaust. I had to rev it a bit to keep the engine running at times, and smoke did come out of the exhaust for a mile or so until I ran it all out.
Next up was the throttle body:
My original intent was to fully optimize it, but unfortunately the TPS and butterfly plate screws were so tight I wasn't able to get them off without the risk of permanently stripping them, so I used some B12 solvent and a toothbrush to clean the plate and a dremel with a grinding stone to take off the screw ends and sharpen the leading edge of the plate.
After:
I did all of this and swapped spark plugs which helped eliminate the cylinder 3 misfire CEL I was getting.
After:
