The way it works is the clutch switch provides a ground for the starter relay, located in the engine fuze box. What I did was find this wire and splice in another wire that I connected to a ground. First find the C-100 connector, Its the huge one just aft of the air box, before the strut mount. It is held together by a captive bolt at the engine end. Unscrew this bolt and the connector comes apart. Its actually two connectors in series but the engine side is the one you want. Find the Black wire with a yellow tracer in socket number 31 on the connector. Its a small wire and this is the one you want. I removed the end cap for access, spliced in another small wire, soldered it and insulated it. I routed the other end to the vicinity of the cruise control mount, installed an appropriate lug and tied it down. Reassemble/mate the connector and secure via the bolt. Its either a 10 or 8mm hex. If you prefer you can work on the other side of the C-100 connector BUT the wire changes to a black/green wire exiting socket 31.
