Con2er
I have searched the forums and could not come up with a clear cut answer so here goes. I have recently replaced the transistor in my IMRC. I called around to a bunch of different places and no one seemed to have the TIP 121. So I was told by someone that the TIP 122 was similiar in every way except it had a higher tolerance so the question is this. Is the TIP 122 a suitable sub for the TIP121. I have a link to the data sheets if anyone can make an educated guess.
http://www.qsl.net/on7pc/datasheet/transistors/TIP122-127.pdf
