If it isn't turning on at all it can't be from an overcharge. The high pressure cuttoff will first turn the fan on high before it cuts off the compressor. Both happen at over 300psi on the high side. There is no way to get the static pressure in the system that high. If it's overcharged it will short cycle as the compressor output drives the pressure up. This sounds much the same as an undercharge (cycling on the low pressure limit switch) which is one of the reasons BrApple keeps saying to only charge ths system witha full gauge set and the associated knowledge.
