Big Daddy Kane
Now Volvo is owned by FMC. Why the difference then in manual recommendations? Just because Volvo is a more prestigious brand name?
My guess it's the engine...
You do realize that Lucas oil stabilizer foams right? Bob the oil guy (IIRC) has a sickeningly stunning demo with an electric motor (turning gears) foaming the Lucas at a mere 300rpm. Imagine idle, 3000, 6000, 7500... Also anything that's goal is to use mass amounts of Viscosity Index improvers (solid particulates used to "thicken" oil) to mask engine problems is a serious step in the wrong direction. Just another typical POS oil additive.
Maybe you should just change to a thicker multigrade oil.
Good thing you politely answered that one Tom. "Who cares if it foams?" :blackeye: Sheesh...
Ford had a TSB saying to run 5W20. So I did. The reason is that it gets 1/2% better fuel economy. So I thought it's the same price.... Now after this incodent I can say that I honsetly don't think that these lighter oils have the lubricity of thicker oils. I did an oil change with 10W30 and my pressures are back to normal. BUT Big Jim was saying something about the pumps causing a wierd wear pattern with thicker oils. That's what I was mainly concerned about.
Yah, but those pistons were subjected to "abnormal wear"!
I beat the piss outta my old 2.5L forever. What killed it was not a bearing issue, but my own laziness. :blackeye:
Use good oil!
I run 0W40 Mobil 1. Mainly because Mobil 1 5W40 is not available locally.
If you get some "seapage" troubles with it try mixing in 1 quart of Synthetic Max-Life 5W30. I actually recommend adding a quart of Max-Life for anyone that gets the common front cover area seapage. It works quite well. My 2.5L used to have this problem noticeably (oil streaks) with 5W30. The 3L was just starting to show some "wet look" (no visible oil though) when I changed the oil last month. (3 years & 20k+ miles)
Heheh, in your case it just may be you need new gaskets considering you're over 100K
OMFG!! I LOVE YOU MAN!
My favs in order:
#1: lubricity
#2: incodent
#3: "Now after this incodent I can say that I honsetly don't think that these lighter oils have the lubricity of thicker oils."
Heheheh, this is gonna get good....where's the popcorn
Let me tell you something Captian Dipsh*t, I have more experence and education than you ever will.
Fruthermore please manage to get through a simple sentence without spelling errors with simple words like experience.
I'll give you lubricity, but just how much grad school have you done?! Furthermore please manage to get through a simple sentence without spelling errors with simple words like experience.
Finally, considering the completely ****ed up Tb shaft I got from you I really don't expect much from you in terms of common sense.![]()
