Well, I took the weekend to figure out some problems from this car I just got.
(2000 csvt)
It had 16.. Yes, 16 codes on it. I cleared it, it went down to 15. :laugh:
I almost wet my pants laughing so hard.
Anyway, I figured out most of the codes but there are some that I cant find an explanation for even in a google search?
Here are the codes I found:
P0155 Upstream Heated Oxygen Sensor circuit fault - Bank No. 2.
P0161 Downstream Heated Oxygen Sensor Heater circuit fault - Bank No. 2.
P0141 Downstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1.
P0420 Catalyst System Efficiency below Limit - Bank No 1.
P0429 Catalyst Heater Control Circuit (Bank 1)
B2535 Right Rear Turn Lamp Circuit Failure
P0654 Engine RPM Output Malfunction
The first 5 I think are pretty self explanatory. But, the B2535? wtf is that about? My blinkers works just peachy. The only thing wrong with any of my lights is a dead reverse bulb.
As for the P0654, got me on that one too. What would cause this issue?
Here is a list of codes I couldn't find anything on, a couple are body codes and chassis codes.
P1188
P282A < wtf?
B1C8A < wtfx2?
C1061
P0429
B2030
C0440
P3080
Thats it for codes.
NOW. Other problems...
Medium braking, to hard braking.. The car pulls HARD to the right. I am thinking a dead caliper maybe? But, the other odd part to this, is under ANY noticeable acceleration, the car pulls hard to the right. I mean even only 20-30% throttle. Very odd, I am going to crawl under it tomorrow to change the oil, and take a look at things. But I wanted to throw it out there in case someone knew what it may be or if it was a common problem.
I am sure there are a couple other things I am forgetting, so I will update my new car, new problems thread when I run across them.
To give people an idea of what I am dealing with here, with past owners....
1. "Someone" took 8gauge power wire for a system, and ran it through the drivers door jam into the trunk...
^ yes, the wire has arched and been burnt. No its not connected anymore. And No, the kid I bought it from wouldn't
own up to being the one that install it.
2. Whoever put the factory radio into the car, didn't bother or didnt know how to hook up the power antenna. So radio stations sometimes come in.
3. The kid I bought it from replaced the tps sensor. On my scan gauge it reads 17% throttle when the car isn't even running or pedal pushed. (This was one of the codes that was on the car when I bought it, and the one that went away after clearing the codes)
Other various things on the car, such as white paint? that looks to be splattered under the engine bay. The skirt caps being completely off the car when I bought it and missing 1 completely. The overhead console missing a bolt. The kid taking the drivers side and pass side front windows tint off, and not removing all of the tint residue. The front bumper was re-painted before, and they didnt bother to tape off the fog lights. Which the kid I purchased it from just said screw it and ripped the fog lights off. There are some other little things too that kinda miff me off.
It just blows my mind how ignorant and lazy people are with their cars. This is a great little car, but people just didn't take the time to take care of it. I mean if its broke, fix it.. If it was installed wrong, go back and fix it.. I got it for a decent price though. So I am going to go through and fix and or repair all the hack job's, and never even attempted to fix jobs..
(2000 csvt)
P1188
P282A < wtf?
B1C8A < wtfx2?
C1061
P0429
B2030
C0440
P3080
Thats it for codes.
