starjammir
HAHA I tell everyone that...thats something Ryan told me right after I gave em the check :S
What color should I use then? I used blue on these. I just want to make sure nothing will loosen.
Getting enough torque on them is more important than loctite. You can add the blue for a "belt and suspenders" approach, but make sure you get enough torque w/ out yeilding the bolt.
If at all possible, find an OEM caliper bolt to use. They are often 12.9, and a lot of them include a specially formulated "loctite" type patch pre-applied. One thing to remember is that the OEM bolts also go through far more rigorous quality control than most bolts you can buy seperate. Historically, there has been a big problem with "aftermarket" bolts not living up to what they promise.
Fwiw, starjammir and i looked at a bunch more of his damage pics last night, and the whole thing was almost definately caused by a bolt backing out, and allowing the caliper to move. The second bolt failed after the caliper was already loose and had hit the wheel. I think it is very clear that warmonger's kit (including the brackets and fasteners) had nothing to do with the incident, and were simply along for the ride . . .
Ya that sounds about right. Still trying to figure out how it came out because when I swapped wheels last week before alignment everything was fine, now its all gone. Thanks again for spending the hour and half looking at the stuff and explaining it all to me. I really appreciate it, now I just have to get it all back together and come down and take you for a ride with the suspension.
Im trying to get Reebs to sell me one of your old calipers and mounts from your SE.
