Hello,
I have for a while now been worried that my clutch was slipping and on its way out, the car is a 2000 SVT with 69,000 miles on it. I actually starting worrying about this at 40K but the stealership I brought it to while under warranty said that nothing was wrong, and even still I don't know if clutches are covered under warranty...doubt it.
With that said, today I tried "the test" of putting the car into fourth gear and hitting the gas, the result wasn't promising....I the revs would start to climb for a second and the car sort of lurched forward and then there was a squeal (I assume serpentine) and then the car would stall. I tried this three times all with the same result...oops just realized that I should have been doing ten to fifteen MPH...damn pays to read the whole thread, now I wonder how much damage I have done.
Wondering if anyone knew if this was indicative of a bad clutch or something else? also would the squealing serpentine be the result of a bad tensioner? I had it replaced a while back under warranty for something similar (high rev shifts causes it to squeal).
Thanks
Thanks
